Huss
You used the SP-445 tank for 120 film? I just use a regular dev tank w no issues.
maryland_fotos
SP445 is for 4X5 sheets. I am using the ARS-Imago lab-box for 35mm and 120.
Actually first try at 35mm today, Delta 100 with continuous agitation. Added a bit of time since the monobath liquid's got a few rolls under its belt. Also, Delta 100 is one of the films needing double processing time in the Df96.
Huss
Huss
agentlossing
You guys are getting good results! I did notice development streaks through the sprocket holes with Foma 100, I think the temp was a little high - perhaps my next Foma 100 roll I will go extra gentle and/or drop the temp a degree or two. I developed for 6 minutes at 72 degrees, which is within the +/-2 degree margin for error. I might try closer to 69 degrees and stick to the minimal agitation.
I had been using the powedered kit and mixing myself, and had probably a three month shelf life no problem, and about twelve rolls before the developer started functioning poorly. I opened a bottle of the premixed (liquid) fom three months ago and unfortunately didn't use it for a while, when I opened it again the other day it was quite exhausted, a dark brown color. Liquid may not last as long as powdered since it has already been mixed whenever it was manufactured.
Huss
I got development streaks like that when I didn't agitate the dev tank enough. First when I went with their recommendation of using the twirly rod thing. Then I switched to inverting the tank - the streaks went away when I inverted for 10 secs every minute which is much more than they recommend.
Huss
Huss
geoffnik
My first attempt with Df96 - 27C - 3 mins
https://flic.kr/p/2jaBjDs
Huss
https://www.flickr.com/photos/geoffnik/49991854476/in/dateposted-public/
Very nice!
Cut and paste the BB code under the Share tab to show the image directly:
geoffnik
Cheers Huss!
Huss
Huss
geoffnik
geoffnik
Huss
Huss
Huss
maryland_fotos
17 rolls? Looks very clean!
maryland_fotos
HP5+ in Cinestill monobath, using SP-445 tank. Linhof Master Technika and Nikkor-W 135 5.6
