Cleaning R-D1 sensor: Copperhill method
R
RML
Guest
When using the Copperhill method, do people use the SensorSweep or the SensorSwipe? And, if used, what size SensorSwipe for the R-D1?
I'm in terrible need of a clean and reliable sensor cleaning method. The dust is getting out of hand.
But still no answer to my question. 🙂
When I owned the RD-1 I found it easier to just take a shot in bulb mode and give the sensor a quick blast from a can of air. I know this is not the the most sensible thing to do but if you are careful (make sure the can is vertical and that you have cleared the nozzle of any propellent) I think it is okay to do in a pinch. I'm usually very careful with my cameras but sometimes life seems too short to be fannying around with swabs and things.
I use the old "glue spatulas" with the lint free cloth. 4 to six wipes from left to right using the solution always works for me on my rd1 and 350d.
It really is nothing to be scared of 🙂
I don't have an RD-1, but to clean the sensor on my Fuji dSLR I use
sensor swabs and eclipse fluid and have had excellent results. These are the products recommended in the Fuji manual for home cleaning of the sensor. Some photo stores sell packs with three swabs and a bottle of eclipse fluid in various swab sizes for different sensors.
Peter
I purchased one of the Eclipse sensor swabs in the size recommended for the Nikon D100 (same sensor ) and used it with Eclipse fluid. I have reused the spatula portion of the swab with Pec Pads. Works great and is easy. Remove the SD card and make sure the battery is well charged.
If you are at all doubtful about using a can of compressed air, try spraying it onto a blank CD, it's very easy to see if there's any deposit. I would not, by the way, use one on an SLR, I managed to get some dust inside the viewfinder of a D2X which required a service to clean.
If you are afraid to clean your sensor because of all the manufacturers warning, you can test your procedure (whatever it is) on a multicoated filter. Any greasy film, crap from the air source, bad techniques, etc will show up very easily on the surface of any multicoated filter. They are very sensitive to the least little anything.
The manufacturers are concerned about owners cleaning their own sensors for a very good reason. Have you ever bought a used lens that looked like the previous owner had scoured the surface with a Brillo pad? I remember my father obessively cleaning his lenses at the drop of a hat. It wasn't until I was I became involved with professional astronomers who have extremely high demands, especially with regards contrast, that they thought nothing of a layer of dust on their optics that I would have previously not tolerated. A little dust that is not near the focal plane doesn't do anything except lower contrast a little bit.
That being said, dust ON the optical plain shows up very clearly especially at small F#. But if you can clean the surface of a lens without damaging it, you can do the same for your sensor. Remember, you are actually not cleaning the sensor directly, but instead the surface of a coated glass IR filter or AA filter. This is not any harder than cleaning a lens except its in a hole with a shutter that wants to close on your brush if your not careful!
Any grease free brush will work. Finding one is the subject of a long thread. Thats why people pay too much money for the Arctic brush. It IS grease free, however.
Dont worry. be happy
Rex
I ususally use the Copperhill kit, but I'm now in NZ for a few months, and though I've got the sensor swipe kit, I haven't been able to get any Eclipse fluid here.
I ended up buying two brushes - the ones to get are white Dakron artists brushes, they are chisel shaped with very fine fibres, and I got the 3/8ths inch size. Though they don't use any glue (I think that's only used on natural hair brushes - avoid at all costs!) out of two I bought, one left greasy smears on a filter (only visible by close inspection with an LED flashlight) and the other didn't. Probably the first one had been touched by the salesperson.
I charge it by puffing air at it from my hand blower, and it works fine.
Bottom line - the artists brushes seem to work the same way as visible dust's. Charge by blowing and use very lightly to pick up the dust particles. Much the cheapest system, and seems fine to me. I don't know how you can avoid a greasy one - maybe you'd have to try them on a filter in the shop.
