M
Makten
Guest
Some of you might have read this thread: http://www.rangefinderforum.com/forums/showthread.php?t=85203
To sum it up, it looks like my Summicron-C 40/2 doesn't reach infinity because it's not properly collimated. That means that the optical cell isn't at the right distance from the bayonet mount, which also makes focus being off at the whole usable range.
I know that the Summicron-C is said to have focus issues with M cameras, but that's a later problem. Right now I want to try to collimate it, which seems to be done by adding or removing shims to move the optical cell in its barrel. Should be quite easy theoretically.
Now; the problem is to get the right pieces of the lens apart. I presume that a Summicron 35/2 is built in sort of the same way, so if you have any experience on one of those I'd like to hear about it! Any help is very much appreciated. 🙂
Here's a picture of the lens from the rear. There's two retaining nuts inside the brass barrel with the cam slope, and I guess one of those must be unscrewed. But which one? I don't want the rear group to fall out. 😱
