Color-Skopar Classic 35mm f/2.5 Manual Focus Screw Mount Lens
Huck, thanks for the link. You have no isda how much help you are!
Lil : I received the 35/2.5 Classic one week ago and I've only been able to shot one roll since. Wide open, I can't affirm the shots were excellent (as I'm still a beginner and lacks comparisons) but at least, there's nothing I found dissapointing.
Coming from the SLR world, I really like the rangefinder's feeling (my OM-2 will remain on the shelf for some times...). I still have to get used to the focusing lever though and not to grab the aperture ring in a first place (ring that I find a litte bit too loose). But all in all, I'm really happy :)
Cloudy : Are you using a Voigtländer adapter ? Does the dot on your lens, once mounted, pop up right on the top ? It's not perfectly aligned on mine and I was wondering if that was correct.
gelmir, yes, I am using a Voigtländer adapter.
I think the mis-aligment occurred between the adaptor and the body, not between the lens and the adaptor. Mine is also about 1 degree misaligment. :)
Question: When you look through the Bessa R2 viewfinder with the 35/2.5 MC Color Skopar, do you see frame lines for that lens, or not?
