confusion.
d4170n
3:48 AM
I was reading an article on f stops. it said that aperture f stops double and halve just like stops in iso and shutter, but they double and halve in area.
this all makes since until i thought about zoom lenses and stuff.
here is the article.
http://www.uscoles.com/fstop.htm
can someone explain this to me any better?
its about the 6th paragraph down in the article
I can tell you where the root of this confusion lies. Then to be precise one should carry out a lot of tedious computations. Because zoom cannot compete with primes, why bother? You have here another good reason to stick with primes.
Anyway, the correct formula for f stop is the ratio f/d where f is focal length and d is the diameter of THE ENTRANCE PUPIL. Things gets complicated because zooms have a variable geometry and thus he entrance pupil should be calculated for each configuration and, yes, each diaphragm.
Hope will help
In other words, we must presume tha the changes in focal lenght are compensated by the effect of changes in geometry on the diameter of entrance pupil.
Hope I stated it more clearly
