jasonhupe
I sent my G1 to KEH, I was the one who started the thread refered to above. They were quick and good, but after a few months the camera started having the same problems. I still have the body as I would not sell it in the condition it is in. Not fun having half a roll of blank frames from the shutter never opening.
Bob Michaels
nobody special
Keep in mind there is essentially nothing in a ContaxG to clean, nothing to lubricate, and nothing to adjust. There is no rangefinder to align. The shutter is electronic. The film advance is a piezo motor, not gears. And, the focus mechanism is a piezo motor, not a helicoid. You are hard pressed to find any actual mechanical parts in there. There is nothing adjustable.
My ContaxG bodies have been to Kyrocera once back when they serviced direct and once to TOCAD. Today, I believe both problems were user perceived and not actual.
Electronic problems are possible, even intermittent ones. But that is cured by replacing a faulty board or component.
scottgee1
RF renegade
Hmmm . . . I hope the viewfinder can be adjusted. The one on my G2 was suddenly rotated about 15 degrees clockwise. Didn't drop it, don't recall any impact . . . just took it out of the case one day and . . . tilt!!
Called Tocad and was told they charge a flat rate of US$174 for G2 bodies. Since the repair is limited to just one element of my camera I was hoping to get it done for less but the trend amongst servicers is clear; prix fixe.
emraphoto
i used to shoot contax cameras quite regularly and these folks took mighty good care of mine.
http://www.camtexgroup.com/
Vancouver
Vancouver
Bob Michaels
nobody special
Called Tocad and was told they charge a flat rate of US$174 for G2 bodies. Since the repair is limited to just one element of the camera I was hoping to get it done for less but the trend amongst servicers is clear; prix fixe.![]()
It certainly sounds like your viewfinder has become loose and needs to be mechanically reconnected or tightened.
Is there a local camera repair guy in your area? Ask the local pros who services their cameras. Most repair guys do not advertise but stay busy servicing heavy duty shooters. I would imagine this is a simple mechanical repair than any competent repair person could handle quickly and inexpensively.
Rangefinder 35
Keep in mind there is essentially nothing in a ContaxG to clean, nothing to lubricate, and nothing to adjust...Today, I believe both problems were user perceived and not actual.
I second that. Over the last 6 years I had at least 50 G1/G2s come through my hands. Only one had a real problem with a shutter, not counting things like dust in the viewfinder, or so. The rest were just perceived by the owners to have some problem. (In one G2 the owner complained of strange thick line in his pictures. It was his strap getting in front of the lens.)
scottgee1
RF renegade
Well, I know my problem is not just "perceived"; my regular service guy had a look at it, confirmed the problem, took the top off and when he couldn't find anything obvious/mechanical wrong, closed it back up because he doesn't have a service manual and can't get parts.
May seem like an obvious question but . . . Rangefinder 35, do you service these? Any idea what might cause rotation of the image in the VF?
scottgee1
RF renegade
Well, I ended up sending my G2 to Camtex for repair and it turned out to be a complete waste of time and money.
Full story here:
http://rangefinderforum.com/forums/showthread.php?threadid=93905
What a PITA!
Full story here:
What a PITA!
andtky
I had the same problem with my G2 about 2 years ago. It was slanted only about 10% to one side. I was not able to find a service for it but luckily I was able to buy a copy of the original repair manual at e-bay. Following the exact description I was able to repair the viewfinder myself. It is not the easiest task - due to the fact, that it is not easy to strip the camera from its cover. But the viewfinder alignment was just a case of inserting some self-made shims (made of plastic foil) under one screw. You have to check the alignment optically against a test chart also provided with the manual.
Andrej
scottgee1
RF renegade
Andrej, this is extremely helpful information! I too will have to find a copy of the manual -- though I may ask my regular repair person to do the work . . .
Cheers!/Scott
Cheers!/Scott
andtky
I think this is what I got:
http://cgi.ebay.com/Contax-G2-G-2-F...319055657?pt=LH_DefaultDomain_0#ht_1049wt_913
I wish you good luck with the repair. Your skilled repair person should have no problem fixing it with the manual.
Andrej
Andrej
sepiareverb
genius and moron
Just send it to TOCAD if you want it fixed. If you want to di¢k around that's another story...
san84
I'm also with shutter problem with my G1. So it would not open for 1-3 time in a roll. Maybe someone knows the answer?
