Yes indeed. So getting 1/300 instead of something closer to 1/1000 can be explained by two reasons only :
- the slit is too wide,
- the 1st curtain roller drum springs are too weak.
In case of a slit being too wide then it will be a mess to fix it because it's related to how the 1st and 2nd curtains are synchronized.
In case of something odd under the shutter cover was braking the 1st curtain, or the 1st curtain drum roller brake (the piece of leather glued on the drum) misbehaving, then you would have uneven exposure with, possibly, some shutter bounce or shutter capping (as a result a large part of the frame wouldn't be exposed).
Overtensioning the shutter drum roller springs often leads, as a famous paradox of both the prewar and postwar Contax shutters, to overexposure at high speeds, instead of underexposure at high speeds. The key of the plot is to tension the springs by the minimum amount so that 1/1000 (or 1/1250 on the Contax II and IIa shutter) and 1/25 are, at the same time, as close as what they can be to their optimum siblings according to the shutter speeds tester.
