Contax I ribbons
I can probably live with it just working at 1/100th 😉
But I would like to see the slow speeds work a well.
I also put in an order with Nobby Sparrow for the frame counter reset button that was missing on this camera.
Maybe you have to oil the gear-train next to the shutter-opening. It is not good when this is dry. Just a tiny little bit of sewing oil, applied with an artists-brush.
I hope that your camera does not suffer from perforitis, that is when the sprocketholes of the film show up in the picture. I've never found a solution for that problem.
I'm looking forward to your results!
Erik.
I've let some mil-spec Break-Free CLP oil work its way into the slow speed gears. 1/25th is now also running okay.
Slower speeds and Z are still not cooperating.
The winding mechanism is also a bit tight now that I've put the top back on the camera. So I guess it's another disassembly and lube job tomorrow.
After sitting for a night the camera appears to be working on all speeds from 1/25th and faster 🙂
Perforitis? Where the film doesn't run straight across the film plane? I would imagine this is due to the film cartidge sitting too low in the film chamber like with the early leicas.
Mr_Flibble;2778112 Perforitis? Where the film doesn't run straight across the film plane? I would imagine this is due to the film cartidge sitting too low in the film chamber like with the early leicas.[/quote said:
Yes, but in Leicas it helps to put some carboard under the cassette. In a Contax I it does not.
Maybe Michaels idea helps to file off the teeth of the fork that goes into the top of the cassette. I will try that when I finally will find some time. Im too busy with work at the moment.
Good luck, Rick!
No slow speeds, but at 1/25th and faster I'm happy for now.
Good luck, Rick!
I'm sure it is a tip I picked up on this forum, I cannot think where else I might have read it. Be careful though, my Contax didn't suffer from perforitis so I have never tried it...yet.
I've redone the Contax engravings on the camera.
Looking at the DOF scale engravings on the focus mount; those should be filled in with black, yes?
Rick, your camera is a Version 5 AFAIK. In Kuc' "Auf den Spuren der CONTAX" the Version 5 has no paint in the dept of field scale-engraving, also not in the index. The big CONTAX word is filled with white. The distance scale is filled with black paint.
Congrats, your camera looks very fine.
Erik.
Shared my slow speed problem with Milo,
He said to check the friction buckles, the leather spacer on the bottom curtain roller and if the ribbons aren't bunching up on the roller.
When I was putting the camera together I like to think that the buckle on one side wasn't running parallel with the other one. Asif there was a slight bend to the plate with the buckle in it.
Will have to see if that's right when I take it apart again.
Meanwhile, Contax engravings filled in
Timings look good now. But the slow speed escapement is sticky. Found a couple of replacement screws to hold the bottom roller.
Next problem is the bottom curtain slipping on the ribbons when winding. Sometimes leaves an opening when the bottom curtain reaches the top of the film frame.
The quest continues
I have same problem Rick. In two slow groups from 1/10 to B escapement is sticky. I have use setting from "white labeled" 1/100 or 1/500 for those "red labeled" groups, it give me 1/25, 1/10 and 1/5s.
I think something is still off in the slow speed gears. The lower curtain gets stuck when it's halfway across the film plane. It can be pushed back up freely, but it just doesn't want to go below that point...possibly the point where the second curtain is supposed to be released.
Same in my camera. I didn't figure out how to fix this. Something wrong with gears setting at slow groups speed? I have try meany different gear combination but not luck.
I need to figure out if this has anything to do with the release mechanism for the top curtain (regulated by the slow speed escapement) or maybe the curtain is snagging on the guides on the back plate.
