Roller and springs...a few pictures to support Deklari's drawings following Grytpype's instructions both of which have been a great help.
The Contax I does have a 'soft pad' it is chamfered to help the blind lay flat.
At the start I didn't realise the significance of the central slot in the blind...
IMG_2832 by
dralowid, on Flickr
Removing the end caps. Again I didn't know these came off. I wonder if it would be easier to sew loops into new ribbons and slide them on having removed the caps. Surely easier than wrestling with them on the shutter???
IMG_2834 by
dralowid, on Flickr
When I did the ribbons I sewed them on quite tight and they have been difficult to get off. I don't know if I can get them on again...
IMG_2836 by
dralowid, on Flickr
What didn't help is the increase in diameter that prevents them from sliding off. You can see I have started to slide the blind off.
IMG_2837 by
dralowid, on Flickr
This picture tells a story. I didn't realise that the brass band around the centre of the roller was a sliding clip and didn't quite understand Grytpype's instructions (maybe I am not the sharpest lens in the bag). So I happily slid the shutter off before realising that I had left the last 'slat' on the roller. Touch and go for a moment or two but I have the blind back together now!
IMG_2840 by
dralowid, on Flickr
Finally the central spring exposed. Now it may be just wishful thinking but as far as I could tell the hook 'anchor' on the left did not appear to be hooked in and therefore anchored. Who knows? I will fiddle with it and see if I can find a break but it does look a mess. I reckon replacing it is well beyond me, my fingers are too big!
IMG_2842 by
dralowid, on Flickr
When blowing this picture up just now I realise the end of the spring should be neatly in the slot. I've done this now but there only appears to be around 3-4mm of anchorage. Is this correct or is this my problem!?!
IMG_2842-001 by
dralowid, on Flickr
Time for a glass of something...
Michael
