Mr_Flibble
In Tabulas Argenteas Refero
Well, no reason left not take it apart now 😉
Are they really identical ?
Excellent! Yes, they almost identical, Except central axle
what about the position of the ribbons spools on this drum unit once installed in a Contax I ?
The trick would be to shorten then re-machine the right end of the central axle of a good Kiev drum unit to install it in a Contax I shutter unit, if possible.
Not too sure, though. Re-machining the axle end so that it can have a slot for the tensioning step would be easy, but what about the position of the ribbons spools on this drum unit once installed in a a Contax I ?
The manufacture of custom springs is no great problem, apart from significant cost. There a specialists in the UK who could do it but machine 'set up' costs would be high. I doubt the cost would drop much with any volume that might be achievable.
The problems I see are:
1) We do not have a good spring to copy. The thing is an awkward double spiral that turns back on itself
2) The chances of deforming the springs during installation are high. OK so my dexterity is nothing like Deklari's but I fear we would mess up a few before we had an acceptable result. The anchorage to the shaft is also very fiddly.
It is interesting that neither Deklari's nor my spring are actually broken. As far as I can tell it looks as if the outer coil or spiral which is unsupported has collapsed towards the anchorage end. Both anchorages are at the same end.
Seeing Deklari is trying heat I have thought of trying to reform it using a gas soldering iron...but have no idea whether this will affect the quality of the spring itself (and I'd just burn my fingers!).
Another thought. Watchmakers or watch and clock restorers. Does anyone have a contact?
Michael
My only hope, what I need this repair ones. From my bad experience, this problems comes from ribbons installation. When I loosing tension on the bottom roller. Do anyone know average of ribbons lifetime on this camera?
Excellent work !! Contax I and Jupiter 8m grate combinationContax I v7, Jupiter 8M 50mm f/2, 400-2TMY.
Erik.
That's an interesting point. I tend to agree with you. The first Contax II I changed the ribbons of was a 1936 model. The ribbons were very weak. They looked quite OK, but when you applied some tension to them, they disintegrated. The fibres no longer had any structural integrity. They were too old. The last one I did was a one owner Contax II I bought it. I have the ribbons, intact, from this one. I picked the stitching apart and extracted them from the curtains and the rollers. These are not falling apart. They feel quite strong and look in sound condition. Same colour, same weave, same blue thread used in the stitching that I have seen in other Contaxes with genuine ribbons. This example is also a 1936. How odd. If you didn't know better you might have been tempted not to replace them. I did, of course, with Aki Asahi material, for peace of mind. Two Contaxes, same year of manufacture, same material, ribbons in completely different condition. No conclusions I can come to about why they have aged so differently. I have no idea. Just reporting what I've observed.What I know, is that when you have in 2016 a working camera with original straps they break almost instantly in use. I think they do not break because of wear, but because they desintegrate from age and the influence of lubricants.
Erik.
