Cursed Camera!?
tunalegs
Pretended Artist
10:01 PM
So reading the 100 year old camera thread inspired me to try another old folder. I found a Folding Conley Kewpie. Although I generally avoid Conley cameras because of their fragile bellows, this one had what look to be replacement Kodak bellows fitted. So I took a chance and bought it.
It all checked out fine, so I loaded it up with film, and set out to run a test roll through it. First shot - shutter release feels wrong. The shutter jammed open. I try gently pressing the shutter release to get the shutter to close (as one may do on these old ever-set shutters) it closes after a few tries. Try testing the shutter again. Nope, just sticks open when fired. Fiddle with the shutter speed dial. Nothing. Forget it. Go home.
At home I figure I'll give it a little flush with lighter fluid, maybe it's just sticky. But when I get home, the shutter works fine. I try it on all settings to make sure. I figure maybe it was just cold outside (although cold in Texas is not that cold).
Take it out the next day. I test the shutter several times before winding on to the next exposure so I don't waste more film. It's warm. The shutter is working. Go to take the shot. It jams. No coaxing will get the shutter to close. So I head back home. Get inside, pull out the camera, this time I'm going to dig into the shutter and find out what's going on - but the shutter is firing fine now. 😱
What is this? A camera that will never take a picture when you want to take a picture, but works fine when you don't? A cursed camera? Maybe I'll mail it to a photographer I hate. :angel:
You may have to open it up to see what is going on with the shutter. There may be corrosion which restricts movement. A few cameras of mine had weak shutter springs, requiring replacement.
"Cursed Camera" would have made a great title for an early 1950s horror movie, a B movie perhaps starring Marie Windsor and Elisha Cooke Jr.
Usually to test out old cameras, especially folders I load a cut to fit piece of photo paper, Ilford MG IV RC operating at ISO 10 in daylight. Bit slow but cheap and easy to process at home with minimal chemicals and equipment.
Maybe a bit of debris that is getting dislodged when you're out and about w/ the camera bumping around?
It's easy enough to make a small gris gris doll of the camera and bury it in the hope of breaking the curse, but I don't advise it, and you'll have to figure out the spell anyway. That stuff tends to come back around.
This DIY video may help w/ your problem. I think you'll need a frog at some point too.
https://www.youtube.com/watch?v=UBLcerB-DgY
