Depth of field notches on rf patch
I assume its the same as the M3..
..in which case, if something has both of its overlaid images (imagine a vertical line, just out of focus) within the width of the notch it will be acceptably in focus. The wider notch at f16, the narrow notch at f5.6
Ted.
I have been using M2's for 49 years and I must admit I have never bothered to figure out the notches! Every time I try to do it - I get a headache! Maybe someone can to a simple explanation of it! I think it is one of those cases of german engineering overkill!
Thanks Ted
I thought that would probably be it, but didn't know which aperture each was for. Cheers.
Now I'll see if I ever have a chance to use them!
Paul
Tom,
Thank you for this post. I can now hold my head high again and shake off the shame of not knowing how to use the notches.😀
Bob
