W
wlewisiii
Guest
Ok, I've gotten some D-76 and am in the process of getting caught up on my sheet film (12 done 8 to go). I'm doing them 2 sheets at a time in my patterson type tank.
The last two batches, I've had one of the negs come out with a big bluish stain down the middle of the negative. I'm not sure what I've done wrong. 9 minutes at 18 degrees C, agitate for the first thirty seconds then two inversions every 30 seconds after that. Rinse in water and fix for 10 minutes. Then into a water wash for 5 minutes before hanging to dry.
Hmm. Thinking about it as I type this message, would this happen if I accidently put the sheet in with the emulsion side touching the tank? I do know the other sheet, both times, came out fine so that makes me wonder...
Thanks for any ideas,
William
William
