deviding unicolor powder c-41 kit?
mh2000
6:43 AM
I've never done c-41 developing, but am interted in trying it... mainly for some b&w 16mm stuff. Can you divide up the powder in the kit and just work with 250ml quantities? I don't want to just waste the whole kit on one or two small rolls.
thanks!
I divided up the two-liter kit powders into two one-liter ones, and that worked OK. But you need 600ml of each fluid for two rolls, right? Just make the full liter, it will exhaust itself more slowly.
It's always risky dividing up powdered chemicals that consist of a number of individual components, but probably not risky enough to be of concern Why not mix the whole thing and divide the liquid up into smaller bottles?
Because by the time you're finished with the first set of bottles, the others will be worthless. This stuff does not last long when diluted, maybe a few months in airless containers.
in stainless steel reels it's more like 425ml per 120 roll, 500 for 120+16mm and 175ml per 16mm... so if I could either make 250ml at a time for a single roll of 16mm or 500ml for other combinations it would be cheaper and more convenient than wasting more than an hour driving time to get the film developed commercially. (35mm is a no-brainer at Walgreens).
Yeah, I remember when Kodak had to stop selling 1lt packs of Xtol because they couldn't put out consistent powder chems in this small quantity.
I guess I'll just have to try it! 🙂
Maximizing the storage life of mixed chemicals isn't all that difficult. Start out with the water from your tap. Chances are that your faucet in the kitchen has a aerator on it to make the water "taste better". At the water plant it was already aerated once because it tends to kill bacteria. Then various other chemicals are added to make it safe and "pure".
Put your water in a big pot on the stove and bring it to a slow rolling boil for about 15 minutes. This will drive off most all the disolved gases, like oxygen, that will spoil your developer. Let it cool. When you mix the developer stir until it's all desolved, but don't whip it to a froth. Divide the solution into smaller bottles filled to the very brim before capping them. Ordinary plastic soda pop bottles are perfect. If you drink the soda the bottle is free. At the worst, you can buy two liter bottles of store brand soda for 69 cents or so and pour it down the drain. Soda bottles have to be able to withstand the presure that the disolved carbon dioxide makes when the bottle gets shaken. That plastic will keep out oxygen too. If you're mixing and using smaller quantities of chemicals start out by getting smaller bottles of soda. Store the bottles in a dark room, closet or such so they don't get a lot of light. Everytime you mix chemicals and store them this way you end up with three brim full bottles and one that's maybe 75% full, which you use first.
I have used Tetenal C-41 Press kits a lot. I was able to do 16 rolls in each batch. I don't do much C-41 anymore so:
I have two 1 liter Tetenal C-41 kits left if anyone is interested, make me an offer.
Leo
