Do you use accessory viewfinders?
  • Yes - I frame carefully and make each shot count.
    Votes: 159 43.8%
  • No - I'm trigger happy, guess the framesize, and fire away!
    Votes: 42 11.6%
  • Sometimes - It all depends on the application.
    Votes: 162 44.6%
  • Total voters
    363
I keep an SBOOI 50mm finder on my IIIa and use it constantly. Obviously, it's not needed on my M3. I also have a 35mm finder, but usually just guestimate the width.
Just bought the FSU universal turret finder and boy is it huge! I doubt I will be using it to frame shots... but I intend to use it together with my Olympus OM kit : I have exactly the focal lengths which are on the universal finder: 28-35-50-85-135 and the finder will help me determine which lens to use 🙂
For wides, CV15, 21 and 28 I use external finders on the Bessa R although I don't use the 28 on the Leica though if I'm wearing contact lenses. I also use a Bessa L which err... would produce some 'interesting' results without a finder 🙂
I use them in many combinations. The 15 on a film camera and RD-1 with two different finders, a 28 with finder on an M5, a 135 finder with a 90 on the RD-1 and a 50 finder with a collapsible Summicron makes my CLE a jacket pocket camera.
Only on the IIf and the Bessa T. On the IIf usually not the 50mm finder, but I do use the other sizes.
I am in the process of making one for 25mm out of a door-peephole which is about the same fov, only circular and fishy. But, very small and cheap!
I have a 200mm Komura coming up which I hope to use without finders. The focussing view of these two cameras should be almost correct, but circular.
Yes--but I lost my $150 VC 50 VF the other day because I stupidly took off the gerry-rigged safety cord. Ouch!
I find that my accessory (mostly) VC VFs are far superior to the camera's and I get much better framing--even w/ quick, hyperfocal shots.
I use the 15 and 21 finder on any of my M cameras with those lenses attached, the 28 finder on the M2-M3-M4, and a 35 finder on those M and screwmount Leicas that require it. I like the view through a finder and I love the look of a finder on the body.
I use the 28mm with the C-S 28/f3.5 on the Bessa R and the 35mm on the Mir with J-12. I have an 85mm for a J-9 I sold and a 3 way made by Argus 35-50-100, haven't use it yet.
Sometimes use the 25mm CV finder but generally make do with the inbuilt M6 28mm, I have a tendency to crop pics too tightly anyway.
Always use the 21mm because the difference is too great.I do find the accessory finders a bit of a nuisance as I work on a minimum equipment basis with the Leica.
Ok, lets turn the question around to the longest length. Did anyone ever make an 180mm viewfinder that could be used on an M8 and an 135mm lens? I have tried this lens on the m8 with good results--in the center.
I don't know if there is a single 180mm one, but I have this one - its a zoom that goes from 35mm to 200mm. One of the click stops is 180mm. Here is a pic.
I may be willing to part with it if the price is right. 😉
I've just received a Zeiss 2.8/25 and I'm currently on my first roll of film using the far edges of the finder on my .72 MP. Maybe I should post some pics to show illustrate my accuracy (I deliberately framed to just barely fit in certain "landmarks" at the edges of the perceived frame).
I always use the accessory viewfinder when I'm using my CV 21mm.
Before mounting the lens, I check with the viewfinder (just held by hand) that that the 21mm focal lenght will "work" (a little like using the frame selector of the M).
I focus and adjust aperture/speed with the body's viewfinder, then I frame with teh accessory viewfinder.
I use one all the time on my IIIf. Even the 50-if it's bright I seldom use the RF anyway.
I've considered sticking the 50 finder on the Pentax MX using the 40 pancake stopped way down.
