DOF Problem
Someone else can probably answer this better than me. But as I understand, the further away an object is, the more difficult it becomes to judge distance, which is why focusing is more critical at closer distances etc. I think using a longer lens can also cause this problem. But I'm still quite new to this, so I may be off the mark.
I've also been told it helps, when wanting to exeragerate the depth of field, to frame the image with an object up close, as a point of reference. Then use the hyperfocal method, and so on and so forth.
Actually it's not a DOF problem, it's a perspective/foreshortening issue. Perspective gets more flattened the farther away the subject is from the camera, which obviously is a problem occurring mostly in landscape photography when using a telephoto lens, although it is not directly the fault of the lens itself. The only remedy is to move closer to the subject, and use a shorter focal length lens if you wish to preserve the breadth of the scene. Obviously this may not always be possible.
Very nice photo, by the way.
DOF problem
DOF problem
hmmm... those all appear to be good suggestions. it was a morning shot so the sun was directly behind me. as far as the lense problem, it was a Bessa R with a 50/1.5 ASPH Nokton ... it's the only lense i currently have for this beast.
