double exposures on IIIF
11:17 AM
Singapore
Is it possible to have double exposures with a IIIF? I remember I read it somewhere in the net that it can be done so. Anyone try it before? Reason I'm asking because I sometime forget to remove the lens cover before taking a shot.😀. It will help to cut down wasted film.
I think the shutter can be cocked without advancing the film, by turning the main shutter speed dial. Can't remember now in which direction it must be turned.
Gabor, I recall that the dial must be lifted when changing speeds but should not be lifted when being used to cock the shutter.
Wizard, it's quite safe. Still, perhaps you should try to remove the lens cap at those times when it is desired that light enter the lens.
Mukul, thanks for clarification !
