I think when both lenses are from the same year of production the lenses are the same.I’m have the Elmar 50mm f/3.5 in M mount. Is it true it has the same optics as the screwmount red scale Elmar but in M mount?
Looks like a reflection to me![]()
In an ad on eBay I saw this picture of an old Elmar lens. Curious glass surface. Does anyone have an idea about what happened to this lens?
Erik.
I mean the structured shine, it is as if a fine sand structure has been applied to the glass, a kind of matting. Maybe only visible when seen on a large screen.Looks like a reflection to me
Thanks a lot for this answer! I'll take a closer look.I think the reflection is showing the surface of what is being reflected. It's not a smooth surface that is being reflected, it has texture to it, which is what you're seeing Erik.
The ring with the old Leitz code name "VALAU", originally for the lens for the the enlarger "VALOY", can be used on this lens both as a shade and and as an aperture control ring. Very convenient and not expensive because the Leitz dark room goods are all forgotten. Available in chrome and nickel.![]()
They're tiny and apart from the aperture control, they handle so well
Unfortunately these days the VALAU rings are going for as much as the lenses.The ring with the old Leitz code name "VALAU", originally for the lens for the the enlarger "VALOY", can be used on this lens both as a shade and and as an aperture control ring. Very convenient and not expensive because the Leitz dark room goods are all forgotten. Available in chrome and nickel.
Erik.
