ZorkiKat
ЗоркийК&
- Local time
- 8:04 PM
- Joined
- Jan 26, 2006
- Messages
- 2,069
zhang xk said:Hello Comrade Jay,
Many thanks for this detailed explanation. So I understand that most I-10s are not good for later Russian rangefinder cameras that has a 28.8mm registration distance. Am I right? Kind Regards
Zhang
Comrade Zhang
It's not only the back focal register different with prewar and many early postwar I-10 which prevent them from being used with later cameras or any other LTM camera which conformed to the Leica standard. There is the well-known difference in thread mount pitch which would cause mounting problems or even damage when one type is fitted on the other.
The prewar I-10 and many of the early postwar editions used a different RF coupling cam movement. I've observed that these I-10 have what look to be a shorter camming. A camera whose RF had been adjusted for these lenses will not couple properly with a later lens with 'standard' camming. The first thing which can be observed is that the RF will not line up at infinity with a 'newer' lens. Second, the distance marks will be off in the entire range. The cam depth of these early lenses seem to be shorter than the Leica standard.
Jay
