Electro 35 GT
picturetaker
10:17 PM
Port Moody, BC Canada
Just received this camera from E-b-y. Pretty good cosmetically etc. But the battery is coming apart inside the battery compartment due to corrosion. I need a sweet trick or two to get the battery out and to clean the compartment. Thanks
Allow me to provide some assistance, kingster. If you look down the Yashica forum a page or two, you'll find a thread titled "stuck battery" started by me. I had the exact same problem you're having.
Now if I could get the damn thing apart so I could check some wire connections & get my GT working again. Or I could always experiment w/ 1/500 shutter speed.
Good luck with it. It's not as bad as you might think.
barry
Thanks for all the suggestions. Used a qtip to drip just a tiny drop of vinegar down the side of the battery and after a second or two, the little bugger lifted right out. Popped the bottom plate off and cleaned the rest of the battery chamber, soaked the battery cover in vinegar and it looks almost as good as new.
While I was at it, cleaned up the inside of the bottom plate and put a coat of paint on it.
Gee things went so well, maybe I will try the top plate - NOT. Need more info to tackle that one yet.
