Filmboy
I'm going to run a test roll on this myself, but just wondered if anyone has any experience of using the Auto mode?
I don't like the metering on the camera much as it is - can't work out if the sampling area is too small, or the weighting is wrong, or what, but I often get better results with guesswork. For example I was in a pub in Soho recently and couldn't get the camera to settle on a reading for the people sat opposite me (the indication arrows just kept flashing no matter where the shutter was set to) so in the end I took a guess, got the roll processed +.5, and ended up with a couple of nice shots.
So does the Auto function produce decent results? In a similar situation, is it going to get it right, or get it wrong?
Also, I've noticed that when the camera is on Auto, it sometimes choses shutter speeds that are not available via the dial - e.g. 1/350, or 1/90. This would seem to indicate that these settings are more accurate than the one that you would select if chosing manually - so in situations where the meter works happily (for example where the light is fairly uniform across the frame) would you get a (slightly) better exposure from the Auto setting than doing it manually?
Or am I just becoming ridiculously obsessive about accuracy... 😀
