Elektrojänis
Hello,
This is my first message on this board and I'm not sure if this is the right area (this might also go to the repair/camera care).
I have been trying to tune up Fed-2 that my father has had for years. He has not used it though... It has been sitting on a booself at least for a decade or something.
Shutter was almost working... The first curtain seemed to work fine but the second was slow and tended to get stuck in the middle of its travel (worst on the slow speeds and bulb).
For a start I took it apart with the help of these instructions http://stephenc7.tripod.com/cameras/fed2.htm exept I have not replaced the shutter curtains yet. I might have to do that too, as i patched up quite many holes with fabric paint and it seems to have developed some more holes (or maybe i just missed them on the first time).
I tried to clean everything as well I could and lubricated the shutter with some sewing machine oil that feels very thin/light.
I also cleaned and lubricated the Industar-26m lens with these instructions: http://mattdentonphoto.com/cameras/industar_relubing/index.html
Everything seems to work nicely exept for one problem...
The problem is I can't get the shutter adjusted to give even exposures. I have read http://rangefinderforum.com/forums/showthread.php?t=30343 and some other istructions like the things on http://jay.fedka.com/ and some others.
I'm not using TV to measure the timings though... I'm using my own measurement setup with two photosensitive diodes, a soundcard (and a few resistors and 9 volt power supply) and some recording software. The photodiodes are set to "read" light from about 3-4 millimeters from the ends of the film opening.
I can get some of the speeds to give even exposures but not all. 250 and 100 are worst. 250 seems to give exposure time almost twice as long on the right side of the frame (looking from the behind the camera) that it gives on the left side. I can get 500 to be pretty even (a bit slow though if I dont want to overtighten but that seems to be typical from what I have read). I can get 50 to be decent (within 1/3 stop) and 25 almost as good as the 50.
On the 25 there is a difference though... left side will get more light.
Basically it seems that I should loosen the second cutain, but I do that, the 25 will get worse.
Some stuff I have read points that the curtains accelerate as they move (and thats quite logical when I think about it) and for this reason the "exposure slit" should get wider towards the end of the movement to get even amount of light to all parts of the frame (logical too). It seems to me that on the 250 and 100 the curtains tend to travel too much in sync and the acceleration causes the problem.
25 probably works the other way round because the second curtain is allready looser than the first and on 25 the curtains cannot "get stuck in sync" like that because the curtains dont move at the same time (second curtain starts moving when the first stops). I can actually get the 25 to be quite perfect but then the others will get worse (or at least not better).
I have not yet put any film through this, but I'm pretty confident my measurement rig is accurate enough that tho problems I have observed are real.
So has anyone else noticed this kind of behaviour when tuning their FSU-cameras? Can anything be done to it or is it just the nature of the beast?
Although it seems to me very thin/light the sewing machine oil could be a bit too heavy/sticky for the shutter, but could it really cause this kind of trouble? Or is there something else that could cause this?
-Petri
-Petri
