Elektrojänis
like the others, I had the same light leak on the left side in 2 of my cams! Don`t worry - its usual, when the 2.nd courtain sticks a little bit OR when You cock, then at the left side, there is a small leak until the curtains go together !
I think this is (or hopefully, was) a leak during cocking. I checked it by holding a flashlight in the lens side (lens removed) and looking from the film side in a dark room. When looking straight from the back I could see no light when cocking, but when I tred looking from the right side of the film port I could see a really thin stripe of light. I had to look in a very low angle to see it.
I moved the second curtain so it will overlap the first a bit more. After this I could still see the light the same way than before, but it seemed to intensity seemed lower. I could make the curtains overlap even more, but I think it might stop the 1/500 shutter speed working (I already had thet problem earlier when I glued the curtains a little carelessly).
I have test roll in it now. I mostly cock it with a lens cap on now, but I will try a few times without.
About the shutter speeds: Urggggh -- I really hate it when I get a new cam and the shutter speeds are different ! It takes about 3 or 4 hours for getting them in acceptabe standards!
Well on this one I have everything a bit slow. Mostly not more than half a stop... 1/25 is a bit more than half a stop slow. I tried to get them faster, but it always ruined the balance between the sides. I did not get the balance perfect either, but I think it's good enough for me.
I'm probably using this mostly with cheap colour print film so half a stop doesn't matter too much... Especially when I know it.
BUT: does anybody know the tollerances ?
Most sources seem to say that within third of a stop is fine.
