analoged
Not cheap, but they do exist...
https://www.ebay.com/itm/Hewes-Stai...622&pg=2047675&_trksid=p2047675.c100047.m2108
Hewes. Hands down.
I have been using Paterson since 1970. Although 120 film is harder to load than 35mm, I can recommend Paterson. What is important, is that the reels are as dry as the Sahara. Practice with a piece of useless film in daylight and in the dark. If the film does not go in smoothly, it can be because the reel is too new. If so, you can lubricate the reel with a soft pencil, gradation "B" or softer. Not only the start, but the whole way. In any case 120 film is much shorter than a 135mm film.If I got a Hewes 120 reel, would it ease my problem? Or should I switch to Paterson?
Here's a trick I didn't see mentioned in the thread. If you're having trouble with the film jamming up it could be because the film is thicker. This almost always happened to me with Ilford FP4 causing no end of grief. Now with a thick film such as FP4, I re-roll the film into my hand first so the leader end is on the inside and the spool end is on the outside. I then trim the spool end and feed it into the reel. That way the tighter wind of the film from the cassette goes in first and ends up on the tight spirals of the reel.
This is what I've said above. The end of the film must go in first.
Erik.
Thanks all, again, for your continuing tips and thoughts. I might treat myself to a new tank too - such is the leakage from the tanks I have I have stopped inverting and instead use the twisty stick. I can't find Nikor or Kalt here, but there are also some European alternatives to Hewes.
After two painless reels yesterday after abandoning the broken one (fortunately no damage to emulsion), this time a 120.
Thanks all, again, for your continuing tips and thoughts. I might treat myself to a new tank too - such is the leakage from the tanks .........
