Agnostic
From my first roll with the FED 3(b) rangefinder (which appears to have a shutter problem at it's highest speed, 1/500th because it has strong vignetting on the left of some shots.) Fomapan 400 in Diafine.
cweg
Nice shots and welcome to RFF.
Agnostic, that dark spot on your first photo is actually a message from God proving to you that you need to get your shutter fixed.
Agnostic
Thanks!
:angel: Finally, a sign!Agnostic, that dark spot on your first photo is actually a message from God proving to you that you need to get your shutter fixed.
I know, looks like shutter capping, I will see if cleaning and a bit of lubrication helps.
planetjoe
Just some guy, you know?
Funny...I was thinking that the capping fit precisely into the composition of that image - it works!
I like these images; not bad for a roll for camera testing purposes.
--joe.
Agnostic
--joe.
Thanks! Actually I have another shot of the daughter of a friend of mine from this roll which I won't post on a public site, but there the vignetting also added a lot to the shot
Some accidents are good accidents!
wolves3012
Looks like it's not quite capping but not far off. After a clean and lube normally comes "adjust" - there's a sticky in the FSU section on how to do this. You have too much tension on the second curtain or not enough on the first (assuming it IS running freely, which may not be the case).Thanks!
It does actually work out on that first shot though...and another "welcome to RFF" here too.
davelrods
Yes that is typical of several of my Fed's and Zuki's. Seems to come with the shutter design whether you want it or not. I currently have three that are unusable because of it.
wolves3012
You need to blame Mr Barnack for it, it's his design that the FEDs and Zorkis are closely based on. Leica themselves had to do a bit of trickery to get the 1/1000th to work properly! The big problem is that the shutter has two, independent curtains and has to be persuaded for both to run in-sync, which is inherently not easily done.Yes that is typical of several of my Fed's and Zuki's. Seems to come with the shutter design whether you want it or not. I currently have three that are unusable because of it.
blazejs
Very nice pictures
Have you used Industar 61?
