bwcolor
Opening Kodafix brought it all back. Wow, that is more memory potent than an old girlfriend's perfume.
Loading 35mm film on a Hewes reel was a snap the first time. I use to have a darkroom, but a changing bag worked great.
In those days it was D-76 and Tri-X. Now it is Rodenal / Stand Dev / Tri-X. I shot my first roll of film since 2002 and first black and white since sixty-nine, or so. I used the same stainless tank, but new Hewes 35mm Reels.
Results are drying, but it looks like a full tonal range. Perhaps a bit dense for scanning, but looks good for wet print..which is never to be.
Questions:
I used distilled water for mixing developer, fixer and hypo. Should I be using distilled for other purposes?
Used water stop bath of 10/20/30 inversion with fresh tap water each time. Is this sufficient?
Do you filter the fixer/hardener returned to storage?
Do you do a final tap water wash in continuous flow, or just a few one-two minute baths in fresh tap water? Do you use distilled water as a last step/wash before drying?
Thanks... I hope that Nikon delivers my scanner rather than discontinuing it. We will see. Two weeks and no word yet.
Questions:
