First impression writeup on xm1 and the new lenses
I was in the same boat wanting a xpro1 for the ovf. After using an xe1 for a day I decided I did not really need an ovf anymore and am saving that extra money for a zeiss 32 touit lens instead.
At the current time, the X-E1 is the same price as the X-Pro1. So that's a real pickle for someone like me trying to decide between the different models and with this new cheaper one flaunting itself in my face all new and cheap and fun looking. 😀
The OVF is useful in very sunny conditions. It also provides an advantage associated with traditional mechanical rangefinders – being able to see outside the frame.
Besides the extra cost there are disadvantages:
o you need to understand and anticipate parallax (though this should be a no-brainer for people on RFF); this seems to be a problem some people even though parallax corrected frame lines and focus regions are available
o the AF works differently; not just because of parallax but because the focus region implementation is different; audio focus lock confirmation is more important too
o the frame lines are more conservative than most mechanical rangefinders; this annoys some photographers (even though it takes a fraction of a second to switch to EVF for precise framing).
o the diopter is fixed which means sharing the camera is inconvenient, and you have to select and acquire an appropriate diopter
o finally more electronic and mechanical components, which means there are more failure points
If the XP1 successor does not have an OVF I will just buy a second XP1 body as a back up because I really find the OVF to be useful.
Hmm. Unaware of such a writeup, but it boils down to:
X-Pro1, X-M1, X-E1, X100S have the same sensor so IQ will be identical
Not exactly true, the X100S has the X-trans II sensor. Supposedly better resolution & signal to noise, and the phase detection AF.
I'm just passing this along:
"The difference from the original X-Trans is the addition of on-chip phase detection pixels. As you know, X-Trans changed the color filter array to a 6 x 6 grid. That let us get rid of the optical low-pass filter, which increased the resolution. Then we switched to a dual-CPU design, which gave us more processing power to work with. Together, those allow a 30% improvement in signal to noise over the previous model, and a 25% increase in resolution."
http://www.imaging-resource.com/new...-x-trans-ii-sensor-proves-Fuji-is-not-resting
So the X100s is basically a fixed lens X-Pro1 (sans leaf shutter) with a slightly better X-Trans chip? And the X-M1 has the original X-Trans chip that is in the X100 and X-Pro1 correct?
I wonder why they did that. I mean, if they have this new tech, why not put it into the new cameras? Is it really that much more that it would make the X-M1 not fit into the price range it's in now?
Still quite curious to see the results from this camera here on the forum. I've had my eye on the X100/X100x and X-Pro1 for a while now. And every time something new happens, I get excited but then always go back to those cameras to ponder.
I always thought that the improvements that Kayce was talking about in that interview was the improvements of the x100s vs the x100 as opposed to the xp1/xe1. Of course the dual CPU path and phase detection cells are improvements vs the xp1/xe1 though.
Gary
Still quite curious to see the results from this camera here on the forum. I've had my eye on the X100/X100x and X-Pro1 for a while now. And every time something wnew happens, I get excited but then always go back to those cameras to ponder.
The original x100 had a normal 12mp Bayer sensor setup. The x100s updated w/ 16mp xtran.. Thus the resolution and noise improvement vs the older x100 plus the dual CPU and phase detection added much faster af and split image focus capability.
I saw a utube video which showed the x100 against Ricoh gr and Nikon Coolpix a. In decent light, the x100s looks to be the fastest af amongst the three.
Gary
i wonder how noticable to the human eye a 25% increase would be?
I can c the difference between the x100 and my xp1/xe1. On the other hand I decided the x100 overall iq is good enough for me, so no intention of ever upgrading to x100s until my x100 finally gives up the ghost.
Gary
Yes
If slightly better means it has phase detect, then yes. IQ is the same in all four cameras, except one can't put the 23/2 lens on the Pro, the E, or the M. 🙂
After using the XTrans II sensor in the X20 and comparing to what I get out of the OMD, I get the impression that the dual processors and improved image processing engine is mainly what allows the files out of the smaller sensor to "punch above their weight" (2/3" sensor is ~4x smaller than m43, and 16x smaller than FF in area).
I get decent highlight recovery potential from the RAF files and can ETTR with the X20. The resolution boosting filter seems to allow use of smaller apertures with good apparent sharpness in the same range as the larger sensor, which shouldn't be the case for such a small sensor.
The main trade-off seems to be that the overall color tones OOC look different than a Bayer format array camera, but not in a bad way, just different. An unintended side effect seems to be, for lack of a better phrase, lack of transparency and lightness to the color rendition, and that seems to be at the grain level due to all the extra processing they do even on images exported as RAW files.
The worst perfromance seems to be from underexposed or DR boosted images, where the so called watercolor effect comes into play. No RAW import I have tried really gets rid of that.
All this is just IMHO what I'm seeing after comparing the two for several months.
That said , you get an amazingly tiny Fujinon equivalent 28-112mm f/2-2.8 lens that performs wonderfully, excellently controlled popup and off camera flash behavior, fast AF, industry leading ergonomics (if you add the thumb rest and shutter extension), and it almost fits in your pocket. Not a bad compromise.
Since the XM1 is almost exactly the same body size as the X20, as long as you are ok with a small prime lens, it seems to be a nice step up without much loss in portability. Of course, the X30, when its announced, could change the game again.
Does this new M1 use the same mounting system as the other Fuji X series? And the only difference for it's lenses that I can see is that they lack the aperture ring? Am I understanding this correctly?
