videogamemaker
It is really not understanding how an encoder works that caused a lot of questions...you are not the only one in RFF.
Encoders are available in rotary or linear forms. Rotary encoder can only rotate 360-degrees...period.
[Liner encoders are essentially a very fine scale and EXPENSIVE, unlikely being used within a lens, else there will have to be a mechanical coupling between the ring and encoder "read-head"].
In AF mode, rotating the focusing ring around and around means nothing.
In any case, rotating the lens ring around and around simply means restarting at the 0-degree position whether you intend to or not. The 0-degree position can be marked or unmarked, hard-stopped or not. Whether the X100 focusing ring can rotate clockwise or counter-clockwise is immaterial...it is still limited to 360-degrees.
So, all you need to do is to selection clockwise or counter-clockwise mode; set desired focal distances and mark the focusing ring.
And, if the X100 only needs 165-degrees to focus from infinity to near limit, then the firmware can and will have to also place any arbitrary ring position to the nearest effective position [and that was how encoders are reset to zero positions in engineering applications].
That's all very well and good, but it's not going to work like you think. If you place a mark on the focus ring, it could be focused at 1 meter right now, and then correspond to 5 meters in 20 minutes after rotations, mode changes, on/off, etc.
I don't know if you've ever used lenses that aren't mechanically coupled or not, but there are so many that can rotate forever, and plenty that have clutches. I have never seen a fly-by-wire lens on a camera or video-camera that has a specific degree rotation hard linked to a focus distance. Ever.
It is very likely for the focus ring to only pass on when it's being rotated, in which direction, and by how much. The lens is not going to pop to a certain focusing distance when it's switched to MF mode, it will stay exactly where it is till the lens is rotated. Focusing marks on the focusing ring will be useless.
