Ko.Fe.
Lenses 35/21 Gears 46/20
The reason I am considering in mid roll to move from 400 to 800 asa is because i have a concern that the light meter is overexposing a little. For instance today, which is bright sunny, no clouds, I would expect f16 at 500 set at 400 asa, but instead the camera is insisting on f8 at 500 at 400 asa, that might be normal but when i switch the camera to 800 asa its telling me what i was expecting ie. f16 at 500.
Its the reason im doing a test roll, just to see how accurate the light meter reading is. Though if I have 400 asa film in the camera, and take a picture with the camera set to 800 asa, using the light meter for exposure, and the picture comes out perfectly exposed, would that be telling me that the cameras light meter, when set to the correct asa that matches the film, is actually over exposing? or underexposing? it gets confusing.
It gets confusing
Use camera to take test shots to determine how shutter and rangefinder works.
Use external, tested and trusted light meter to check camera light meter, not S16.
You don't need to test it on film, because camera light meter is not linked to the shutter.
BUT. If you will find out what camera light meter and external light meter are disagree, take different ISO shots to have it proved on film. This might help with return, repair, adjustment.
And before all of this, make sure what battery is OK.
