F456
I used to worry about the idea of adjusting and matching a Leica body to a particular lens (yes, the Noctilux is responsible for this thought). If a body were matched to one lens, wouldn't it be out with others that had always been fine?
Leica UK's Mr Herriot(t) performed a quick adjustment to my M7 and my recently-bought Noctilux yesterday and clarified the process. If I understand things right, you can match a body to a lens, in which case you cannot guarantee continued good operation with other lenses.
BUT... lenses do go out as well (contrary to what you sometimes read). If Technical Service check and adjust both the lens and the body then you should be fine with your other lenses as well, assuming they are correctly adjusted, of course.
This all sounds extremely obvious in hindsight, but I thought it was worth stating. Focus shifts or not - I couldn't even get a focused shot at full aperture; now we're ready to try again! I am using a 1.25x viewfinder magnifier with a 0.85x viewfinder, to help things along.
Tom
Tom
