Four Pinhole Photos
cz23
11:08 AM
Four from the MM with a Skink pinhole lens. - John
Thank you, everyone. Much appreciated.
mfogiel, yes, handheld at 1/15. The Skink is 24mm at f/110. I set the slowest shutter I can manage, crank up exposure compensation, and then adjust exposure using ISO and the histogram. These were at 2500.
BTW, if anyone knows a regular M-mount lens that will get close to this look, I'd appreciate hearing about it. A faster shutter would be nice.
Sounds about right. I've used the Skink Zone Plate disk a bit as it is down to f/47, which nets a bit more hand-foldability.
Far as I'm aware, nothing else produces a look quite like a pinhole.
G
Very nice, Godfrey. Lovely tones and texture. I'll definitely order one of those.
BTW, I posed a question in another pinhole thread about a lens cap for the Skink to reduce dust ingress. I've since found that the rear cap of a Sigma E-mount lens snaps on perfectly.
John
Good to know! And thanks!
G
So you are using a $7.5k camera to make pinhole photos? Are you sure you don't need a Hasselblad with more pixels? :D
Just kidding, your photos are beautiful, especially the second one with the man on the bridge!
I think You'd need to adapt a plastic lens from one of the old box cameras. For example, there is a whole movement around a Brownie Hawkeye with a flipped lens. I imagine, with careful searching, you will find some plastic lenses for 35mm as well.
So you are using a $7.5k camera to make pinhole photos? Are you sure you don't need a Hasselblad with more pixels? :D ...
Um, one printed set (11 prints) of my Leica M9 pinhole photos netted $3200. Two more sales like that, and it will have paid the cost of the body.
Can't complain about that. :)
G
A similar look... at one point Konica made a 35mm disposable film camera that sported a 17mm lens with fixed aperture.
Some shooters pulled the lens off of these, drilled out the aperture to make the lens faster, and that created some interesting looks. Mount that Konica lens into a body cap?
Gee, that's pretty motivating. Congrats.
Thanks!
Yes, it was a fabulous thing. He called me up after seeing a couple on line and hunting me down. We spent a lot of time picking just the right set, and I then made several different prints to find the right balance of sizing, tone, and color. Once the prints were finished, he had a framer do them right, decorated his condo with them, and held a reception to show them off.
A lot of work, but worth it. I look forward to having the time to do more Photography like that again.
G
Thanks for sharing that. Say what you will about Pictorialism, but it moves people.
I hear you on the time issue. Work sure does interfere with life, doesn't it?
Thanks!
G
