Yes, it is an early (1980 or earlier) AF Nikkor 50mm 1.8 lens. Super sharp and have used it on the F3T a few years ago with great results. But, cannot figure what to do here?
I take it that once mounted, I slide the actuator over the top to the point where it clicks (or all the way over to where it stops?) and just use it at the largest aperture of 1.8?😕
I just took the FTn and pointed it at my blank (white) computer monitor screen and obtained a reading of 500, that is at maximum aperture, 1.8, I presume. Then, I took the lens off and put it on another Nikon SLR and obtained the same reading.
So, am I good to go with that information checking out?
If so, that means I will have to use 1.8 even outdoors? Might be tough with a maximum speed of 1000!
