lynnb
I can recommend the 35/2 and 50/1.4, as well as the 50/1.8.
I've borrowed the 21/3.5 and it's very good.
I'd like the 85/2, have a look at Jane Brown's portraits with that lens.
Edit: I used to own the 28/3.5 and 200/4, both very good lenses. I used the 200/4 for portraits and landscapes. It was a very good portrait lens, even though "only" f4 it had shallow dof at closest focus, and smooth bokeh.
David Hughes
David Hughes
Surely the joy of all these lenses is that they are found everywhere and can be dirt cheap. You just watch and wait and one turns up at a silly price like a fiver. (Unlike Canon which I've often had to pay six or seven pounds for... )
Regards, David
Regards, David
ChrisN
Striving
I wish I'd kept my OM 24/2.8. I still have the 28/3.5, 35/2, 50/1.8 and 100/2.8. All excellent lenses.
Keith
35mm f2, 50mm f1.2 and the 85mm f2 are probably my favourites.
alistair.o
100/2.8 is a must. 50/1.4 is great but pricey... I'd get a cheapo 50/1.8 first, just to see bow you like it. If you're gonna go wide, go wide! 24/2.8 is my fave.
yes, I have them all and more,
Incidentally, they all work well on digital bodies, too.
I second this. Not only wide, but 'right up close'
maitani
most zuikos are excellent and weigh above average compared to any brand.
50/1.4 late
24/2.8
28/2
35/2 late
40/2
21/3.5
55/1.2
but here's my list of absolute worldclass lenses & standouts:
21/2
35-80 2.8 zoom
50 1.2
55 1.2 (at f2)
50/2 macro
90/2 macro
100/2
i think the 180 2.8 and 180/2 are also up there but I never owned them.
for a while i had 20+ zuikos, then i switched more to rf camp at least for the classic focal lenghts.
now in OM I remain 21/2 and the 35-80 zoom. and an early 50 1.8 covers the 'compact' needs.
50/1.4 late
24/2.8
28/2
35/2 late
40/2
21/3.5
55/1.2
21/2
35-80 2.8 zoom
50 1.2
55 1.2 (at f2)
50/2 macro
90/2 macro
100/2
sreed2006
Alex aka glassportal,
Your originally stated objective of a 3 lens kit is practical, and wise.
But in the world of Zuiko lenses, it really is hard to stop at 3. Just so you know.
Olympus OM by sreed2006, on Flickr
I would be at a loss to tell you the best of these. I like them all.
Ljós
I declare you the Imelda Marcos of Zuiko lenses ;-) ;-)
Keith
As we say in OZ .... 'Strewth!'
sreed2006
Let's just hope I don't have to flee the country suddenly.
Ljós
Let's just hope I don't have to flee the country suddenly.![]()
Yes! May you "wear" your lenses in peace. With so many to choose from, you are not likely to wear them out any time soon
Paul Jenkin
I used to use OM1 and OM2n to shoot weddings and portraits in the early 1980s and then, almost by accident, moved to Canon and then Nikon. I'veowned a few OM bodies in the intervening years but I'm now building a small collection of lenses as an alternative to a Leica set (well, the OM2n is only fractionally larger than an M6 and the glass is exceptional.)
My current set up:
- OM2n
- OM2SP
- 24mm / f2.8
- 35mm / f2
- 50mm / f1.4
- 100mm / f2.8
I don't need f1.2 50mm lenses and the 100mm / f2.8 is a beautiful lens, a third of the price of the 85mm/f2 and only marginally slower. I usually carry 24/50mm or 35/100mm. Occasionally, 24/50/100mm and, with just one body, it fits more than comfortably into my Billingham Hadley. I shoot mostly travel and landscapes but like to dabble in street / reportage.
This kit is very discreet, not hugely expensive and yet extremely good quality.
My current set up:
- OM2n
- OM2SP
- 24mm / f2.8
- 35mm / f2
- 50mm / f1.4
- 100mm / f2.8
Texsport
Though they're not for a "standard kit", my OM favorites are clearly the 180/2, 250/2 and 350/2.8 ED -IF lenses.
Expensive and rare, but brilliant.
Texsport
Texsport
jcb4718
There isn't much difference between the 100mm f2.8 and the 85mm f2. The main design difference is the minimum focussing distance (1m vs. 0.85m). Olympus patented a 'close focussing correction' whereby the spacing of the front-to-rear lens elements changed at close focussing. The 85mm has it and the 100mm does not. That aside there's not much difference between them, hence the 100mm is better value (because its cheaper). They are both great portrait lenses with a wonderfully smooth out-of-focus. Any of the standard 50mm lenses are fine but I favour the middle-of-the-road f1.4. The f2 MACRO is a big lens. Its the sharpest (of just about all the Zuikos, probably) but I only use it for macro, its just too bulky. The 24mm f2.8 is a gem, one of the best wide angle lenses, period. The first series of Olympus lenses (85mm f2, 100mm f2.8, 24mm f2.8 and the standard 50mm lenses) emphasised compactness. The second series were all f2 (e.g. 50mm MACRO, 100mm, 90mm) and, it seems, size and weight (and cost) were no longer constraints. They are higher spec, no doubt, but they are also bigger, heavier and a lot more expensive. I use the 24mm f2.8, the 50mm f1.4 and the 85mm f2. If I knew what I know now, I might have bought a 100mm f2.8 instead of the 85mm. The 50mm f2 MACRO I use for copying work only.
eko
Going against the grain somewhat, I love my 50mm 1.4 silvernose with a very low serial number - supposedly terrible but gives absolutly beautiful photographs - wouldn't swap it for anything else (well maybe a 1.2)...
I was also impressed with my 28mm 2.8, and I found the 50mm 1.8 'made in japan' very ordinary (for colour photos anyway - running some b&w through it at the moment....).
But to be honest you probably won't be unhappy with any of the primes (you'll probably end up with versions of each of them - that's what zuikos do to ya).
Ljós
Interesting, I did the same thing. I settled for a low serial number 50 1.4 silvernose. Not a Summilux-killer, but I like it.
Greetings, Ljós
dtcls100
Zuiko gems
Zuiko gems
I have over 30 Zuikos. My favorites are:
18 f3.5 -- incredibly low distortion (almost none)
28 f2.0 -- sharp with pleasing liquid quality to images
35 f2.8 shift (rare mc version) -- aside from convenient shift operation, renders skin tones beautifully
50 f2 macro -- sharp with beautiful bokeh
90 f2 macro and 100 f2 macro -- sharp with gorgeous bokeh and rendering
35-80 f2.8 -- all round most useful Zuiko, sharp as a prime with beautiful rendering.
I have alot of other great Zuikos (21 f2, 24 f2, 24 f2.8 mc, 24 shift, 35 f2, 50 f1.4 and 1.8, 50 f3.5 macro, 300 f4.5 mc, 75-150 f4. I really like them all, but the ones i listed above are my absolute favorites.
Zuiko gems
eko
Greetings, Ljós
Greetings - glad you found the same thing. I've never understood the disdain it gets on forums - I found it quite beautiful.
Ljós
Yup. Check out the beautiful images RFF member 'Shab' graced the Zuikoholic-thread with (page 85 or so onward).
wblynch
I adore the silver-nose lenses. Especially early 50/1.4's (make sure they're clean and use a lens hood)
My favorites, 24/2.8 - 50/1.4 - 85/2
(I can substitute the 28/2.8 for the 24 and the 75-150/4 for the 85)
