GSN and GT stopped working.
ully
ully
4:51 AM
Sammamish, Wa. USA
Both of them just set away for a few months then I return to them and they are both dead. Light meters don't work. Checked battery which registers correct voltage. What gives?😡
I left my GT with the shutter cocked for a few days and this drained the battery - the manual does warn you that this will happen. To check the batteries condition you really need to measure the voltage under a typical load. I've read that the camera presents a load of 100 ohms, so try measuring the voltage with a 100ohm resistor across the terminals. If it's much under the 4.5V, the LEDs won't light
