peter_n
Hi Doug - I have the full Adobe Acrobat product so I think the easiest thing to do is simply download a copy of the form and scan it directly into Acrobat and create the text fields myself.Doug said:Hi, Peter -- I just used the .pdf form as a background graphic and overlay the text... First I did it in Photoshop, then Illustrator, then Adobe's page layout program InDesign, then I created a FileMaker database with text fields on top of the background form. This last might be useful if your travel involves taking different packages of gear to different destinations repeatedly (though you can apparently re-use the form as long as it's legible.) So it can be done in various ways depending on your preferences and software. But probably the simplest way to use it would be to print out the .pdf and fill in the blanks by hand! 😀
If I manage to find the time to do this I'll upload it to the forum so others will be able to use it. It would be a regular PDF form that you can enter data into and save on your hard disk.
