Heavy Distortion FUJIFILM XF 23mm f/2 R WR Lens
Thanks for the suggestions, but I returned the lens already. And the camera as well.
DXO is not for free, right? And there are many lenses that don't have distortion at all. Isn't it a paradox to have to purchase extra software to correct lens design flaws? To me the heavy distortion displayed by this lens is a serious flaw.
I predict you will be returning a lot of lenses and cameras.
You get tons of good advice (and some ridicule..) and choose to listen only to the one person who says buying more gear is the solution?
In all fairness to the many helpful replies, the OP got many replies filled with careful and correct explanations (that perspective distortion is not a lens distortion). The OP then ignored all this and said that the X100 didn’t have perspective distortion. Then said they’d try a bigger sensor to fix the “problem”. Then there might have been a teeny tiny bit of lighthearted well meaning ridicule.
There is a book by Amael Adams where he explains perspective and lens distortions very well called The Camera. He used LARGE FORMAT to get rid of it. Why stop at full frame?
My large format pinhole photographs are even more distorted and the camera doesn't even have a lens! Let alone a Fuji one.
Perhaps I need an 8x10 one instead? Or perhaps it's possessed, and is there an exorcism plug-in in LR?
Obviously the hole is somehow defective. What type of pin did you use?
8x10 pffft. 11x14 as a starting point!
because he is obviously provoking people that wanted to help him understand that his lens has no distortion and to teach him basics...
I do not see any provocation on his part. Clearly he thinks there is an issue with the lens. I am not sure I disagree. Mocking his opinion is mean spirited and puerile.
If the OP doesn't like the Fuji 23mm f2, cool. Plenty of people out there use it and love it, despite any optical issues, which I believe are pretty minimal. Hopefully he finds a camera/lens that meets his needs and post some images for the community here to enjoy.
I'm still a bit confused by the whole thing, but I've also bought and sold lenses for reasons that probably don't make sense to anyone but me.
This sort of thread will continue to reappear as long as we live in the current physical model of the universe and have a shared sense of perspective, which leads to both converging lines at infinity and keystoning as a result of projecting usually wide angle fields of view on a 2 dimensional surface.
Phil Forrest
