sreed2006
Preface: I cross-posted similar questions on the Flickr "Yashica TLR Unlimited" group, so sorry if the cross-posting offends anyone. I don't know how many people read both groups.
crooked_frames by sreed2006, on Flickr
The negatives above were taken with a Yashica 124G that I have not used much before . When I scanned the negatives, I noticed three problems:
1. The frames are rotated counter-clockwise on the negative strips.
2. The spacing between the frames is inconsistent.
3. None of the pictures came out with sharp details anywhere in the frame.
The rotation of the frames can be seen easily on the left of the picture above where the bottom of the upper frame meets with the top of the lower frame. The frames are not square on the strip. When scanning, each frame is tilted so that either I have to crop (to about 90% of the picture), or scan big enough to get all four corners and then rotate the image in an editing program, then crop it back to square.
The variation in spacing can easily be seen in the differences of gaps between the two left frames and the two right frames.
For scanning, I am using an "Epson Perfection V500 Photo" with the stock negative carrier. I tried emulsion side down and emulsion side up, and there's just no fine detail anywhere to be found in the pictures. I expected better.
Any ideas on what is going wrong here?
