Pioneer
I wish I could advise you but I don't think I can. But I do agree with Ko Fe. Neither the brand of camera nor lens matter in the least. All that matters is that you really use that camera.
No matter what you buy; use it to take lots and lots of pictures. Choose at least one negative from each roll and have it printed. It really costs very little to have a negative printed nowdays and you will learn so much from that print and each one after that.
Photography is so much more than the camera and lens. That is only the start. In the beginning just pick a camera and lens you can afford and then plan on wearing it out by the end of your year of ownership. Plan on papering your walls with actual prints that you and others can look at and that you can learn from.
If you do this without fail for the next year then you might have an idea of what tool you need next. And that may not even be a camera or lens at all. It could be a flash, it could be a tripod, it could be a filter or a lens hood. Whatever you need to make your next year's prints even better then your first year's prints.
I doubt that you will actually do this, not many do. Instead, like so many others, you will go buy another camera or another lens. But none of that will actually make you a really good photographer. But it will make you a collector of cameras and lenses.
