P
pradeep1
Guest
Newbie to the forum. Recently went crazy and bought three rangefinders. A known broken Canonet 28 for $14.00. A supposedly great condition Yashica GSN which has a broken shutter - working with eBay seller to get refund. And finally today, my most anticipated camera arrived - a good condition Canonet GIII-QL17.
So I get the camera, put a new 1.5v Zinc Air 675 battery in it with a little aluminum foil to help it out. Check the battery light...it works! Encouraging. The shutter works properly at all speeds. The light meter works as best as I could test it indoors in the dark. The self-timer works. Lens is smooth, viewfinder etc. are clean, foam lightseals are wrecked, but all is as expected.
I leave positive feedback to eBay seller and put my camera away to play with later.
So about five hours later, I take out the camera and the shutter does not go off in automatic mode. Do the check battery and the light does not come on. I take out the battery and reinsert it with a bit more padding, etc. It doesn't work.
Then I peer into the battery compartment and see this (see attached photo - area of concern was selectively brightened) -> The negative terminal point is below the plastic side of the compartment! :bang: :bang: :bang:
I don't know how this happened? I didn't drop or move the camera much since I put the battery in earlier tonight.
I am finding my patience with vintage rangefinders dwindling and all the initial excitement of me doing the Cartier-Bresson style shooting seems like a dream. I am longing to go back to my film SLRs and my digital cameras. They seem more reliable than these rangefinders. 😛 Just kidding.
In any case, if anyone knows how to fix this, let me know. I saw the baseplate can be removed from another thread. I don't have the tiny screwdrivers needed to do that, but I'll get them tomorrow. Is this an easy fix? I am guessing that once I pop back out the negative terminal and fix that, the camera should go back to being okay?
Patience is a virtue. . .
And this will be the last time I buy a camera from a seller on flea-bay. I've been burned or at least not 100% satisfied too many times. Either it will be from an RFF member directly or through their auction...no more trusting non-camera persons.
