If it has haze, you want to do everything you can to try and clean that haze with chemicals, rather than ever wipe an element. The right solution (according to Leica) is 94% distilled water, 4% ammonia, and 2% hydrogen peroxide. Wiping with tissue and cleaning fluid is sure to remove the coating, instead of removing the haze. With 7 elements in 5 groups, lens coating is very important to the Summarit.
The front section unscrews, section in front of the aperture. You will see a retaining ring on the inside of that section for taking out the first group. That should leave the front element inner section exposed.
I removed that lockring, and the front section is still firmly stuck in the front silver/chrome ring. And I've removed any screws that come in from the side.
Does the front section push out?
Or does it unscrew out?
Or do I need to heat it all up to loosen things up?
