Pfreddee
My choice was Other. I use a trash can.😀
With best regards,
Pfreddee(Stephen)
With best regards,
Pfreddee(Stephen)
I make a digital contact sheet by putting the negs into Clearfile transparent negative sheets, then scanning the whole lot in one go on a flatbed, add text via Photoshop and then print off an A4 physical copy.
How do you avoid the reflection off the sheets ? I've tried doing that but the scan was useless because there were always reflections on the sleeves
35mm workflow became much easier/faster lately due to a minilab scanner I picked up. WOW this thing is fast (5 minutes for the entire roll at highest res) and TIFFs are great, straight out of the scanner.
Develop (home)
Scan (home)
Import TIFFs to Aperture
Archive negs
How did you scan the film back in 1984 and get ALL the data off the film?
NegatiNegatives are shredded.
For 35mm, I simply load up 6 frames in the Plustek holder and preview scan them all one by one. If any of the 6 make the cut, I scan at 7200dpi, go make a coffee, and then come back 5 min later to finish the scan.
I backup to a suitcase buried in Mexico. It's a tried and tested system.
Do you have a high ranking military officer you give them to?
So now calling someone's ideas "misguided" is insulting, rude, and I'm calling you names?
