Roger Hicks
And wet-print B+W, I take it. That's what I do.Scanning has a degree of learning to do, but once you get to your correct set up, then it is only a matter of time available. I have a job which permits me to scan while I work, so in this sense the time does not cost me anything. In terms of speed flatbed is the slowest, then dedicated scanners, then a hi res adapted digital camera. I scan on Nikon CS9000 and a full 35mm film at full resolution takes me about 4 hours.
I would generally suggest to shoot colour on digital and B&W on film, unless you REALLY want to get that creamy colour negative film look which comes from shooting MF - particularly appreciated by portrait and wedding photographers. The software of choice is Vuescan - by a large margin - and as to the choice of the scanner, it will primarily depend on how big you want to print. Here is a useful article to look through:
https://www.trippingthroughthedark....5mm-black-and-white-negatives-with-the-d800e/
