bwcolor
BTW.. high contrast and richer blacks are pretty easy. What is a bit more challenging is keeping the subtle tonal range. After all this text on an expensive monitor has deep black and high contrast.
Mostly, it seems a little flat and to lack good contrast. Any advice?
I think really rich blacks and good contrast come from learning to see light, and you seem to have a good eye for that. Treating it as an add on often just leads to harsh or unnatural looking images, though obviously some people want that look too. Rich blacks often hold some detail which avoids the sooty look so famous in "soot and chalk" pictures most people get when they first start looking for good blacks and contrast.
Personally, I like your original image much better than a lot of stuff I see. The soft enveloping light is intact and seems very appropriate for the subject. I'm sure some tweaks could improve it, but you can't change it a whole lot without loosing that effect. I think it is nice to see something different than the usual heavily processed stuff that often has no real sense of light.
First, I always shoot with a yellow filter. Tri-X can have really wonderful contrast. I find that pushing it to 1600 gives really amazing contrast, but I'm sure at 800 it would be more in the middle and less extreme.
This is Tri-X @ 1600, straight from the scanner [Canoscan 9000]
kelsey by scottkessler, on Flickr
I usually use D-76 but Rodinal also gives great results with Tri-X. HP5 at 400 in D76 probably has the best contrast I know of at box speed. I always fix for a bit longer as well, 7 minutes or so.
This is HP5 in D76, also straight from the scanner.
passionate dog by scottkessler, on Flickr
Finally, I could suggest Fomapan 100 developed @ 100 in Rodinal - easily the deepest blacks and whites I've seen yet. It's just less versatile being a slower film. Again, straight from my scanner.
sarah by scottkessler, on Flickr
By the way, this is a good example of an image I have shot that has the look I'm after. I din't do the dev though, a lab did. I want to figure out how to do this at home with my dev and scan. It's Tri-X with a 1 stop push.
Why isn't anyone just saying
"Underexpose and overdevelop"
That's what you need to do anyway, underexposure gives you deep/empty blacks, while overdeveloping stretch the highlights up, creating greater contrast in your negative.
It's dependent on film type, developer and developing scheme though, so you need to experiment to find what works best for you.
I'm afraid it's the other way around. Overexpose and underdevelop. When a negative is underexposed, if you contact print it for maximum black, you shall notice that the entire frame is too dark. The same goes if you enlarge it. Therefore, you will unknowingly try to correct the "darkness" (lack of brightness) of the shot, thus avoiding true black. On the contrary, if the shot is too "bright" (overexposed), you will be forced to print it "darker" (with deeper blacks).
As most people have said, once you're scanning, you just need to adjust the scan in Photoshop or whatever you are using.
If it's a scan, grab the curves in Photoshop and give them a nice "S" shape and you will get the sort of look you want.
Really Tri-X is a great film and can give you as much contrast as you like. You can get all Ralph Gibson style straight out of the neg by over exposing and developing in Rodinal 1:25 for 11 or 12 minutes rather than the usual 7 or so but using a flatter neg and scanning will give you the ability to control this much better.
35mm Tri-X is very well suited to this. It's when you want more subtle tonal gradations where medium format has some advantages.
This one is 35mm Tri-X in Rodinal 1:25 for 7.5 minutes and has a nice deep rich black and charcoal tones that I like:
So, what happened here? I just got these back from my local lab that did processing only. It's Tri-X at 1600, and he uses TMAX developer. I scanned this straight and made no adjustments other than cleaning up dust. Is it a bit overdeveloped?
What many of us have been saying all along -- underexposed and overdeveloped!
No detail in the shadows -- that comes from underexposing (pushing the film 2 stops).
Almost no detail in the highlights -- that comes from overdevelopment (I am assuming that you told the lab that you pushed the film 2 stops, and they adjusted accordingly).
'Expose for the shadows, develop for the highlights' -- every photographer shooting conventional black and white film should know this basic rule.
Yes, if you haven't made any adjustments to the scanner settings the bleached highlights and solid blacks are under exposure and over development.
You could have got detail in the highlights and the shadows if shot differently, and made your high contrast image in post processing. You may say 'why do that when I can do it without post processing?' but the answer is easy, in years to come you may change your mind about the Ralph Gibson look, you may want a baby picture that isn't dated to 'the Lomo school of 2013', you may want more refinement. So there is no going back if the negative is thin and blocked.
Even Ralph Gibson's high contrast images, made even more aggressively by over exposing and over developing, are finished in 'post processing', high contrast printing in the darkroom to control the balance of blacks and whites. See a reproduction on the web and the shadows often look totally black, but see the print and subtle detail can often be seen, a testament to the fine control he has over the process. Letting the Lab decide the style and quality of your output is one way to do photography, but I'm sure most people here would agree that being in control all the way through the process is a better way.
