How to make a finger strap for your camera
hoot
green behind the ears
6:11 PM
Vienna, Austria
Want an alternative to a neck, shoulder or wrist strap? Try a finger strap. I just made one; it's fun.
1. Buy about a meter (or 3 feet) of black nylon strap. This can be found at mountaineering shops. You'll only need about 20cm or 8" for a single strap, but the stuff is cheap and it's better to have some spare material. If they sell different widths of strap, choose one that is almost as wide as the first joint of your right hand's middle finger. (Note: the strap can only be used for your right hand, but I don't think you actually need to be right-handed to use it.)
2. Cut the strap to a length between 25cm (10") and 18cm (7") depending on the width of your right hand's middle and ring fingers. I've got relatively thin fingers for a man, and my strap is 20cm (8") long. It's probably a good idea to wrap the strap around your fingers, leaving about 1cm (0.4"?) space between them, and take a measurement. (Note: to cut the strap, I used a sharp exacto knife.)
3. Cut three small holes into the strap (see attached picture). Unless the width of your middle and ring fingers varies greatly, the second hole should be in the middle of the strap. (Note: I used the same knife to cut the holes, folding the strap in half along the length to cut a semi-circle along the fold.)
4. Seal all of the cuts over a flame. If you've got the same type of strap I have, it will eventually fall apart at the cuts. A small flame (lit match or candle) will seal the edges by melting the loose nylon string. If you get big blobs, cut them off and re-seal. The strap should be as flat as possible.
5. Align all of the holes and sew them together. If you use regular thread, go over the holes several times to be safe. After all, this should be strong enough to carry the weight of your camera.
6. Attach and test the strap by placing it over your camera's right hand strap lug (i.e., the one near your right hand when you hold the camera to shoot). Push down so that the lug protrudes through the hole. Thread a key ring or carabiner hook through the lug, making sure it is too wide to slip through the hole in your strap.
7. Slip the middle and ring fingers of your right hand through the strap and you're ready for some street action! When not using the camera, just let it dangle from your fingers. I find that this puts less strain on me than a wrist, shoulder or neck strap. If the strap is a tight fit, that also means that a purse-snatcher lusting for your Leica will be dragging you along!
Do you get the idea from that sling from leicagoodies?
I always wonder how convenient would that be, wouldnt a wrist strap be more useful?
You will still need to put the camera somewhere if you want to grap something else
but it's really nice of you to share this
I want to hear your comment
Yes, the sling did inspire this, but I'm not out to make competition for them. Two reasons prompted me to make my own strap rather than buy a sling. One was that I wanted it to be wider and thus sturdier; the other was that I'm a cheapskate. However, the sling is no doubt a wonderful tool.
I'm not so hot on wrist straps because my wrist starts aching after a while. Sometimes I use the leather shoulder strap of an everready case and wrap it around my entire arm (making it look like I'm laying Tefillin, heh).
Poptart said:
Unfortunately, I lost those two fingers in a moshing incident back in the '80s.
Ouch! I'm sorry. It must be rather difficult for you to hold a camera steady.
a wrist strap with a grip is the ideal combo, for me.
i hold onto the grip lightly with the known security of the strap.
a finger strap likely would have me feeling a bit claustraphobic.
i've made a few wrist straps for the same reasons you made the finger strap🙂
joe
Joe, I'm actually planning a special wrist strap, too. What I envision is a strap that will hook onto both strap lugs for added stability, wrapping around the bottom of the camera *and* screwing into the tripod thread. This way, for a bottom-loader like the Leica, you'll just let the loose bottom (!) dangle when changing film, rather than having to stuff it into a pocket. Will post a how-to if I succeed.
Love your current signature, by the way. Very funny. 🙂
