How to turn OFF the SP meter?
That's what I thought, but just confirming. Keep it in a dark place or remove the battery are the only two options I guess.
Thanks,
Bill
When neither was an option for me, I used to crank the ISO on the meter dial (on the right side of the body when viewed from the front) all the way down to the lowest ISO (50? I don't recall). This would close a four-bladed iris over most of the meter window, reducing the intensity of the light falling on the meter.
Not sure, in retrospect, how much battery life this saved me.
--joe.
If you are using zinc-air batteries, I'm not sure how thy at works ... once the plastic is removed from the holes, the chemical reaction proceds even if you take the out of the camera. So replacing the seal (e.g., a small piece of tape) would be necessary to completely (if possible) stop them from losing juice. Granted there would be no electrical drain, but zinc-air ain't silver-oxide. If you get a full CLA from John, he upgrades the circuit to SR44 type silver-oxide battery. That's a good thing.
Trius:
Thanks--I use the Kanto/CRIS MR-9 adapter w/ SR44 batteries and store them in individual small plastic bags at room temp. when not using. I never touch the adapters or batteries w/ my fingers-I use a pair of bamboo tongs.
Bill
Current drain is ridicuosly small. The batteries will last more or less the same as in a shelf. At least that is my experience with the SP.
