Sparrow
Would one not have to be prepared to “keep” a digital shot with blown highlights that had it been on film would have been OK in order for that initial premise to be valid? methinks there is a flaw here
The best justification for shooting film is simply, "I like to."
PS... Hi Rueben!
i found it enough of a problem to return to film for mist of my stuff. drove me bonkers!
I get 'more' keepers "when" I'm "drunk".
I looked at the manuals and decided madness or the devil lay, hidden, somewhere in those sub-menus … and decided to stay within my comfort zone for now, but hey-oh there is more than one truth 🙂
FWIW... with digital I "set it and forget it". Aperture Priority, Auto ISO - with range of 200-3200, "Neutral" or "Standard" color setting, highest JPEG setting (typically - don't usually do the raw thing), single point/adjustable focus, Auto/continuous focus, Default auto metering, single frame/non-continuous shooting. Done. I just control aperture (99% of the time), sometime +/- exposure, and what focus point to use.
Digitals are like MS Office, Word, or Excel or other "bloatware". Features on pre-digital mechanical cameras were limited to what you can do electro-mechanically with physical parts and engineering that can be cost-effectively massed produced and would ad to the value proposition to the end user. This resulted in a pared-down "sensible" feature set. With digital, adding more features equates a couple lines of code, cost next to nothing to implement, and requires no additional physical parts. What's essentially "free" is also plentiful, and those features become marketing tools that can be bragged about by salespeople in camera stores and additional lines of bolded text on the side of the camera box... In other words "puff". - Hence "feature bloat" and menu upon menu. Ignore it. Just because it's there doesn't mean you have to use it.
Set it and forget it.
See what I mean, why would I need to know that lot? my cameras only have three controls, shutter-speed, aperture and focus why would I need to overcomplicate it?
I see both sides of this equation but consider it a non-starter. You can do virtually all math with a calculator that adds, subtracts, multiplies, and divides that costs $2.00. It's all you need, really. Or - you can buy at TI 83-Plus graphing calculator and does lots of other stuff that's useless to you but not useless to others. You use whatever you "know" and ignore the rest.
I'm new to DSLR-dom. Had mine about a little over a week. I read the manual, set it up once, customizing to how I like to shoot, and that's pretty much it. It's as simple to use as a manual camera now that I've set it up to how I like. I don't envision myself futzing with much at all. In fact, what I do like about it is that a wheel right by your right thumb adjusts the aperture (or shutter speed, or +/- exposure...) with all "photographic variables" (ap, ss, iso) clearly visible in either the viewfinder or LCD. It's just as easy as any manual camera I've used.
I see where you're coming from, having made a similar case based on personal biases prior to owning a DSLR. In use, however, I used two buttons. The "mode" button and an inset wheel that sits just below the "release" that controls aperture or SS depending on what the mode wheel is set to.
There is actually less "futzing" with the same level of manual control, since I do not have to manually focus, I can see the aperture and shutter speed in the VF and set it with a single, conveniently-placed wheel I don't have to look at as the settings are displayed in the VF (and/or LCD), and don't have to advance the frame. I roll the wheel to get the aperture I want, 1/2-way depress the release to focus, click the frame. Futz-free after it's set up. All other features are largely ignored.
The only "futzing" I do is manually setting the white balance... Yes, it requires one to futz a bit but auto white balance is a joy to have when shooting color, means you don't need to use correction filters when shooting in tungsten light, and can shoot at higher ISOs without filter factors cutting down the film speed and it works better as color temp is adjustable as opposed to the "fixed" setting of a filter. Taking filters on and off is a more cumbersome form of futzing to me, all things considered.
I wonder why?....I use both mediums - as the fancy takes me, without noticing any significant loss of quality either way. 🙂I think my photos are OK now, I am pretty sure they would be less OK if I had to switch to digital, that much seems clear to me and should to you.
Sparrow - I went to film exclusively (at an early age too, it's all that was available), to digital (my only camera broke, digital was "what was in... in the early 2000's), to film (preferred the film look, digital was still evolving, high-end cameras that were "as good as film" were out of my price range and would obviously be obsolete in rapid time, good film cameras and lenses were downright cheap on the used market), now to both since the cost of really good digital cameras has come down in price, IQ quality has improved, and their obsolescence factor has (like PCs) stabilized. I'm only being honest based on my experience. There is no "higher keeper" ratio based on some magical properties of whatever medium you're using. Automation has made digital cameras easy to use, in fact easier if you did a "motion study", as any manual film camera with the same level of control, and the "menu" futzing is largely myth. I held the same bias/myth but now I see it differently.
Fine but that is the truth for you only, your original premise is true for you, you cannot then apply it universally.
