I just bought a Canon Rf....
kzphoto
8:09 PM
Bay Area, CA
It's really neat! Came with a 2.8cm f/3.5 W-Nikkor in pristine condition.
How do you identify the model of the camera?
Max speed of 1/1000, and it looks like it has a flash sync too.
SN 84009.
Any hot tips?
Photos!!!
that's a IVSb or IVSb2, depending on the shutter times: the "normal" times indicate a IVSB2, a series with 1/20, 1/40, 1/60 is a IVSB. I have one of each and I like them very much. One of them is quiter then my Leica IIIF, the other about equal. Great cameras. You'll have fun with it.
No 1/20th on this camera. 1/60, 1/40, and then on down to the 1/25 / B setting. I am amazed this camera works as well as it does. the shutter sounds seem right on with a recently repaired Rollei, and a Fuji GS690.
You're right: I typed too fast and now I both of them out of the closet:
The IVSB has 30, 40, 60, 100, 200, 500, 1000
The IVSB2 has 25, 40, 60, 100, 200, 500, 1000 and a small red dot at the base of the film wind know, on a curled ring, to set as a reminder of number of frames available on the film. I think you have a IVSB2 then.
You do know these cameras are great for double exposure ? Just turn the shutter dial counter-clockwise again when you have taken the first picture; that way, the camera is cocked again without transporting the film.
Stefan.
A Canon IIIA had no flash sync side rail .
The OP's camera has a flash side rail so combined with the 1/1000 of a sec top shutter speed and a single piece top shutter dial make this Canon a IVSb model.
Stefan.
Just a correction, the IVSB has the slow speeds split at 1/25 and the IVSB2 at 1/30.
Don't worry about the camera, you got a killer lens, including, apparently, an impossible to find 34.5mm filter. Quite rare these days and worth twice or more the value of the body.
kzphoto: Are you serious about the filter?
What's the outside diameter of the lens in mm? A slip-on Series 5 or 6 could allow the use of filters and shade (that's what I ended up doing with my Summaron 35/3.5).
