Disaster_Area
Gadget Monger
I have a GR1 in full working order I might be parting with soon.. let me know if you decide to go with the Ricoh
Thanks for all your responses. A couple of quick points:
I like the Nikon 28 but for some reason that $1,000 is a price barrier.
Looks like I am mulling between a Contax T3 and a Ricoc GR-1.... now if on the Contax came with a warranty I'd plump my cash down.
Have a great day all!
Contax T2
... feels right
Most point and shoots only determine the focus distance with a half press. Then, when the shutter button is fully depressed, the lens is moved into focus and the shutter is tripped. This is the case with the T2, the Oly Stylus, the Leica CM and Minilux, and the Nikons. Trying to capture a decisive moment is far more difficult. You must be very good at "anticipation".
A couple of years ago I found myself looking at the same cameras. I bought a T2 then sold it. Bought a T3 and then a GR1 and still have both.
Some thoughts:
Anyone considering a high end point and shoot should be aware that the GR1 and the T3 are the best of the bunch when it comes to shutter lag. Both of these cameras actually focus the lens with a half press of the shutter. When you fully depress the shutter button, the shutter is tripped, and a photo is taken. With the GR1 or the T3, you can acquire focus and then wait for the decisive moment.
As far as reliability, I've heard more stories of bad circuit boards in GR1s than in T3s. I suppose you should try to get a late model of either one.
Another thing to consider is manual ISO. Only with the GR1v can you manually set the ISO. With the GR1, GR1s, or T3, you must use exposure compensation to push or pull your film.
Ergonomics are better with the GR1, but the viewfinder display is better in the T3. The info in the GR1 viewfinder can be difficult to see in sunlight.
The thickness of the T3 makes it less comfortable to carry around in a pocket.
Finally, as nice as these cameras are, they remain full of compromises. The lenses are great and you can get some great shots, but I still find both cameras fidgety. I find that I get far fewer keepers on a roll compared to my results with a rangefinder. So when I want to go small and light, I will usually grab the Bessa R3A with the 40mm Nokton f/1.4 and wear it on a sling. The benefits are almost always worth it.
