Impressions of the M10
Here is another photo with the new Summaron 28 f/5.6 and the M10, both is color and B&W, the latter processed with Silver Efex. Shot at ISO 100, f/8 and 1/125 sec. (I'm posing both version because some people have expressed interest in this).
_______________
Alone in Bangkok essay on BURN Magazine
I like the punchy Tri-X look of the B&W conversion. It's especially good on the white building planks and in the clouds top left.
Try backing off the red filter slider and maybe use a control point on the tree in the center to brighten it up and maybe punch up the contrast and/or structure.
I really like the image and it's just a few tweaks away from being great.
maggio- thanks. I've done some dodging with control points as you suggest and may have to try to play some more with the red slider when I get some time.
There are several issue when you use SEFEX: one is whether to bring in the finished color picture, the original DNG, or the "flattened" (low contrast) version of the finished color picture. I generally find the latter works best. For example, in this picture, to get the fence planks dark, works best with the flattened picture.
Mitch, I like your B&W conversions.
I've had my M10 for exactly 3 months and it is such a wonderful camera. Looking forward to seeing more of your images.
I have the original version of the 28/5.6 Summaron. It has been a fun little lens to shoot. Especially, shot into the sun.
As far as the DR is concerned. I've had one since 2012 when I sent it to DAG to have the near helicoid milled down to fit the upcoming M240 (which I assumed would have LV).
The new M10 seems to have more clearance for the near portion of the DR helicoid. So, the DR seems to work fine on the M10 with the exception that there is variation in how far the near helicoid extends. It seems that some of the DR lenses might need a little of the helicoid filed off.
I've had the DR on my M10 for the last week and it is just a wonderful lens. Also, it is nice to shoot into the sun!
I have the DR, so all that is left here is to get an M10.
It would have been easier for me to first have an M10, followed by finding a DR!
There are several issue when you use SEFEX: one is whether to bring in the finished color picture, the original DNG, of the "flattened" (low contrast) version of the finished color picture. I generally find the latter works best. For example, in this picture, to get the fence planks dark, works best with the flattened picture.
Interesting! I haven't tried that. What format do you save the flattened version in?
You will love the DR and the M10. When you put it on the M10 mount it at the the stop of the distance portion (at the 3'4" mark). Then slowly turn towards infinity. It probably won't bind. If it does then the near helicoid is binding and you will have to file the near portion down just a little. It shouldn't matter much.
My lens doesn't have any portion of the near helicoid. Which is ok. It just means it will never work with the goggles... which is fine for me. I can use the LV for near. And, it will work on the M240.
Good luck.
There was a video on this by a photographer in Hong Kong, but it is no longer on the web. The idea is the same as making a low contrast scan of film for further processing. It makes sense particularly when you want to process a color file into high contrast B&W.
Assuming you're in Lightroom, you simply take a "finished" color DNG or RAW file, i.e., one on which you've set the WB, Exposure and other settings in the LR "Basic Panel" and then apply the Flatten Preset that you've made. My preset has the following values, which I copied from the example in the video:
Contrast -71
Highlights -25
Shadows +37
Blacks +13
I also have the following settings in the HSL panel, but I don' remember whether that is by design or whether those setting happened to be in there when I made the preset:
Hue
Yellow -38
Blue -17
Saturation
Yellow -29
Blue - 39
Luminance
Yellow -15
I generally apply the Flatten Preset to a DNG color file on which I done a quick basic processing. You don't need to save the flattened file: you simply bring it into the SEFEX plugin.
_______________
LightBender - Thanks for the kind words.
Yes, I was interested in the Summaron 28 because I saw shots with it taken directly into the sun, particularly some by Ian Watts. I bought it mainly because I thought it would be great for shooting into very bright and contrasty light. Also, I saw that it doesn’t create starbursts, which I dislike although some people love them. With the M10, as the f/5.6 maximum aperture should not be a problem, I’ll try it for street photography at night when I get back to Bangkok in October.
_______________
If I get an M10, I'll keep that in mind.
One plus of the M9-P is that its RAW files play exceptionally well with Nik Software, both Silver and Color Efex Pro. Oh, and their RAW Presharpener is amazing.
maggieo - That's the same with the M10 files; but I think that in both cases, particularly for B&W conversions, using a low contrast ("flat") file gives you more scope for B&W particularly when you want a high contrast look.
If you want a true rangefinder, Leica is the only game in town. With no competition, prices are what the market will bear. Lots of competition for the SL and S. Doubt sales for those models are robust.
ptpdprinter - Actually, this thread i.e. aimed at impressions of the M10 rather than its price.
Anyone is welcome to post M10 photos.
M10 | Summaron f/5.6 28mm | ISO 1600
_______________
This is actually a very lovely photo. The circular window in the house behind also picks up the cupboard handle plate. Intentionally or otherwise, very nice :)
