Industar 61 focus off by feet
Robmtdew
3:26 PM
I recently picked up an Industar 61. I shot a roll through my M3 and the majority of the images were badly out of focus. In one image it looks like things are somewhat sharp about 20 feet behind the object that I was focusing on. Today while looking at the lens, I discovered that the rear retaining ring was very loose (close to 3 complete turns). Would this most likely be the reason why things are so out of focus?
Rob
Thanks Brian. I was hoping that it was just the retaining ring but suspected that the helical was started at the wrong thread. There's a lot of evidence of prior tinkering. I guess at this point it's a matter of identifying the correct starting point on the helical via trial and error and then using a ground glass at the film gate. Thanks again.
Rob
At 3ft, close focus, the RF cam should be about flush with the mount. That is how I determine when I get the correct starting thread.
Good luck.
I'm not a DIY'r and don't have the tools or dexterity even if I did want to do the work myself.
So who DOES work on these lenses? 😕
